I have a few questions if somebody could help I would appreciate it.
1. No ground lug on alternator. I assume it just grounds through the engine ground. Is this correct?
2. I will include pics. I am doing this on my 16 chrysler 200. Should I run my charging wire to the battery or to the distribution panel?
3. Should my amp wire be hooked to the battery or distribution panel?
4. If I am to hook both up to the battery I am Looking for a good way to hook up the factory wires and the new wires.
It's hard to see on the pictures but the factory wires are crimped on to a piece of metal then bolted on to the terminal lug.
Thanks
Chad
Sent from my LG-LS998 using Tapatalk
