User Tag List
Results 1 to 4 of 4
  1. #1
    Join Date
    Aug 2005
    Location
    PENANG
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Smile Ford 5cd changer din unit
    hi all,
    I just bought from a friends, used 5 cd changer (built in changer) din unit. I got this problem, all the button has no illumi, all functioning just fine but just that. Anybody has any suggestion on the wiring side. Anybody has a complete wiring diagram for it. info Model # YEFM031253. Ill try search the net but couldnt found any info. thanks in advance.
    Similar Threads:
  2. #2
    Join Date
    Mar 2000
    Posts
    14,186
    Mentioned
    1 Post(s)
    Tagged
    5 Thread(s)
    Default
    If this is a stock unit you will need to run the illumination wire to it.
    Im not sure how you wiried it if your car is not a Ford...
    But I would find the pin out for the illumination wire on the vehicle side and send it to the illumination pin on the radio side. You can give it a switched 12V for maximum brightness at all times...
  3. #3
    Join Date
    Aug 2005
    Location
    PENANG
    Posts
    2
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Smile
    what color etc it is? any hints. wont it defect the LED?
    I had 1 player with the same prob and connecting illumi wire to 12vcd now the display has no illumi at all. wondering what is the suitable voltage for it.
  4. #4
    Join Date
    Mar 2000
    Posts
    14,186
    Mentioned
    1 Post(s)
    Tagged
    5 Thread(s)
    Default
    Like I said Im not sure how you have it wired up. The car its in or anything.
    Its probably the hue colored wire though
    Find the pin out for illumination and put a DMM on it to check for voltage when you adjust the light dimmer. That should tell you if you need a low voltage or the 12 V for the illum wire.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
[Output: 57.33 Kb. compressed to 51.13 Kb. by saving 6.20 Kb. (10.81%)]
