User Tag List
Results 1 to 2 of 2
  1. #1
    Join Date
    May 2006
    Location
    Charleston, SC
    Posts
    15
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default JBL GTQ400 Questions
    Hello all! First time poster, long time reader. Anyway, I just bought a JBL GTQ400 amp. Unfortunetly, I didn't look at the amp close enough before I started running my power wire. After running my wires, I noticed that the amp has two power connections!! I am by far not an expert, but I have installed a few amps, and have never seen a requirement for two power connections. Is it a necessity to use both power connections, and if so, why does it have two instead of just one?
    My second question is, can I use my Fluke multi-meter to measure how much power the amp is sending to my sub? I am using this amp to run my 4 ohm Kicker CVR-10. This sub has two voice coils, so I bridged the amp to power each coil. I just want to make sure that I am sending (as close as possible) the same amount of power to each coil.
    I appreciate any help thatb I can get. Thanks for your time!
    Similar Threads:
  2. #2
    Join Date
    Jul 2006
    Location
    NW Ohio
    Posts
    5,261
    Mentioned
    0 Post(s)
    Tagged
    2 Thread(s)
    Default
    I'm assuming you bought this amp used and didn't get a manual with it...
    You can download a copy of the manual from JBL... I'll save ya some trouble though:http://manuals.harman.com/JBL/CAR/Ow...0-400%20om.pdf
    Turns out that is one of their Biamp models... so yes you will need both inputs.
    The manual will show you how to configure... so you're all set
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
[Output: 48.92 Kb. compressed to 44.27 Kb. by saving 4.66 Kb. (9.52%)]
