+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Ported box setup.
  1. #1
    Member callandor2k has a spectacular aura about callandor2k has a spectacular aura about
    Join Date
    Feb 2010
    Location
    Iowa
    Posts
    82
    Default Ported box setup.
    Ok I am going to ask yet another debate question.
    I know that the slot ported boxes are better in their own way than tube ported boxes and vice versa. I've been reading through some of the sub owners manuals and some give specs for sealed, round ported and slot ported boxes. Sealed being the smallest, round ported being the middle sized and slot ported being the largest of the three boxes.
    Now call me a worry wart or what ever. But I don't like running an amp that has a higher rms wattage rating than the sub it is pushing. If anything I would under power by a little than take a chance on overpowering it by a little. Since I have a 1000w rms amp I am thinking of running 2 x 500 - 600w rms subs in a modified round ported box. By modified I mean round port converted into a square port. The reason for this is space. If I were to go with a slot ported I would take up about half of my trunk space and be using 1 sub. If I go with a square ported box I can get 2 subs in same space and be utilizing the amps full power (theoretically speaking).
    So here is my rough design. Tell me what you think.
    I know that this isn't the way some of you would do it. But this is just an Idea. Since I have time to explore options till I can afford to buy the subs and wiring.
  2. #2
    Platinum Plus Bwcad1 has much to be proud of Bwcad1 has much to be proud of Bwcad1 has much to be proud of Bwcad1 has much to be proud of Bwcad1 has much to be proud of Bwcad1 has much to be proud of Bwcad1 has much to be proud of Bwcad1 has much to be proud of Bwcad1 has much to be proud of Bwcad1 has much to be proud of Bwcad1 has much to be proud of Bwcad1's Avatar
    Join Date
    Aug 2005
    Location
    Ohio
    Posts
    10,892
    Default
    Using less the what the amp produces is a hell of a lot easier on equipment. when your running your amp at maximum potential everyday your stressing the components. i know you said you wanted your equipment to last for a long time so that's not such a good idea for you.
    That box design while work definitely has severe limitations. You don't have enough port area and you will have insane amounts of port noise.
    If your running a single amp your better off without the divider and moving the subs to the outside and port to the middle.
    Round ports and square ported boxes take up ruffly the same amount of space when properly designed.
    That box is still better suited for a single sub but i can tell you want 2. That's completely OK you just wont have an optimized box for the sub.
    Also your cutout diameter for a 12 should be like 10.75-11 not 11.97
    SQ master in the making JeremyC has much to be proud of JeremyC has much to be proud of JeremyC has much to be proud of JeremyC has much to be proud of JeremyC has much to be proud of JeremyC has much to be proud of JeremyC has much to be proud of JeremyC has much to be proud of JeremyC has much to be proud of JeremyC has much to be proud of JeremyC has much to be proud of JeremyC's Avatar
    Join Date
    Jan 2005
    Location
    New Mexico
    Posts
    2,464
    Default
    I want to add something to your theory about over and under powering.
    There really isn't such a thing as underpowering a sub. All your doing is limiting its max output.
    Its just like turning the volume down, or limiting how loud you can turn it.
    Say your running a 2K watt rms amp on a 1000 watt RMS sub. As long as your gains are set properly, and you never turn your deck up till your input stage of your amp is maxed your sub will never see 2K watts.
    Say you do turn the deck up till the input stage of your amp is maxed. All you have to do is turn the deck down the equivlent of 3db and your back down to 1K watts rms.
    Cut the deck by 3 more db, and now your at 500 watts rms.
    See what I'm gettign at here.
    Most of us match the RMS output of our amp to the rms rating of the sub. That way we can get every last drop of output when we want it, and still know were not going to run into thermal issues.
    There is nothing wrong with running an amp with a higher rms than the speaker its conected to. In some situations the added dynamic headroom can be a plus, especially in your higher end SQ cars.
    And the extra headroom can keep the amps from running as hot when you do decide to crank it up a little. BUT..... You have to know your system, and how its set up. So unless your willing to pay someone with the right tools, and a lot of experiance, or you really know what your doing. I wouldn't sugest it.
    JC's Customs
    "Taking care of all your car audio and performance needs"
  4. #4
    Master of My Domain Ryan from Ohio This person is "the shit" Ryan from Ohio This person is "the shit" Ryan from Ohio This person is "the shit" Ryan from Ohio This person is "the shit" Ryan from Ohio This person is "the shit" Ryan from Ohio This person is "the shit" Ryan from Ohio This person is "the shit" Ryan from Ohio This person is "the shit" Ryan from Ohio This person is "the shit" Ryan from Ohio This person is "the shit" Ryan from Ohio This person is "the shit" Ryan from Ohio's Avatar
    Join Date
    Mar 2000
    Location
    Elmore Ohio
    Posts
    14,592
    Default
    Pretty much what Bill said.
    If you dont have the room to run the ported properly then go for the sealed.
    Ported boxes not done properly are no good.
    What subs are you going to run? That will play an effect on what box size and how much port area you truly need.
  5. #5
    Platinum Plus MobileAudio219 is a splendid one to behold MobileAudio219 is a splendid one to behold MobileAudio219 is a splendid one to behold MobileAudio219 is a splendid one to behold MobileAudio219 is a splendid one to behold MobileAudio219 is a splendid one to behold MobileAudio219 is a splendid one to behold MobileAudio219's Avatar
    Join Date
    Oct 2004
    Location
    Sullivan Missouri
    Posts
    5,242
    Default
    Quote Originally Posted by Ryan from Ohio View Post
    Yep.
    Also certain subs don't favor ported boxes, and certain subs don't favor sealed boxes.
  6. #6
    Join Date
    Feb 2010
    Location
    Iowa
    Posts
    82
    Default
    I decided on one of these 3 subs.
    MB Quart RWE-304
    Hifonics Brutus BRZ12D4
    Hifonics Atlas ATL12D4
    Dual sealed chamber cause I don't have the trunk space for a good ported box. But will most likely be one of the Hifonics. Not sure if I really like the looks of the Atlas series. It's different. But it looks like the cone part is plastic, though I am sure it's not.
  7. #7
    Join Date
    Feb 2010
    Location
    Iowa
    Posts
    82
    Default
    Quote Originally Posted by JeremyC View Post
    What I meant by underpowering the subs is where I am not running full sub rated rms to it from the amp. I know it's not really underpowering it. But that is what I call it.
    I guess I should of said. I would rather run a little under the rated RMS of the subs than run too much.
  8. #8
    Join Date
    Aug 2005
    Location
    Ohio
    Posts
    10,892
    Default
    Quote Originally Posted by callandor2k View Post
    Just bear in mind going that direction puts is more stressful on your equipment.
    The atlas cone is plastic. there are tons of subs that use plastic cones now. Some of mine do.
    Join Date
    Feb 2010
    Location
    Iowa
    Posts
    82
    Default
    I won't be running full RMS of the AMP anyway. But if I want to do it every now and then, it's there to use if I want it.
    If setting gains at 3/4 radio volume and sqrt(wattage x Ohm load)= Voltage is accurate. I rarely go over 1/2 volume most of the time anyway. And if I do, it's not for very long.
  10. #10
    Join Date
    Mar 2000
    Location
    Elmore Ohio
    Posts
    14,592
    Default
    You will be fine.
+ Reply to Thread
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
[Output: 82.07 Kb. compressed to 72.36 Kb. by saving 9.71 Kb. (11.83%)]
