Car Audio Central (Forums)
Go Back   Car Audio Central (Forums) > Open Forums > Car Audio Discussion
Reply
Thread Tools Display Modes
Old 04-01-07   #1
SQ master in the making
JeremyC's Avatar
JeremyC has much to be proud ofJeremyC has much to be proud ofJeremyC has much to be proud ofJeremyC has much to be proud ofJeremyC has much to be proud ofJeremyC has much to be proud ofJeremyC has much to be proud ofJeremyC has much to be proud ofJeremyC has much to be proud ofJeremyC has much to be proud ofJeremyC has much to be proud of
Default ??????? !!!!!!!!! ????????
Yeah thats about how I feel. I finally got some free time, and got everything back in the accord. The mids are imaging really well, and she sounds pretty good, BUT. The damn noise is still there.
Ok so here is were I am with my trouble shooting. Hopefully someone can come up with something to try.
I know its comming from my audio control DQS. As soon as I turn it off, or disconect the RCA wires that go to my amp it goes away.
The noise isn't alternator wine, and it does it with the car off.
It is DQS output and amp gain dependant.
It is not volume dependant.
It does it on all 6 channels, but is the most noticable on the tweets.
The DQS has been sent in and benched checked. It tested fine.
So here is were I am with the car.
Everything receives power and ground from the same spot. I even tried running the DQS power and ground to the battery, but nothing changed.
I tried every jumper combination possiable (inside the DQS) and nothing changed.
I tried gounding the QS chassi. still there.
Tried grounding the RCA sheilding. Still there.
Tried moving the DQS in the car. Still there.
Reran my RCA wires. Still there.
Tried resetting my gains, using 2 diffrent setting. One at 8 volts output from the DQS, and one at 2 volts output. Once the amps were set, the noise was just as loud at 2 volts as it was at 8.
"More info on how I set my gains."
I started at the headunit with a 0db 1000 herts track. I set all 6 RCAs to 8 volts with zero clipping.
Then I set the DQS input stage. Same way, 0db 1000 herts track, turned the input up till the output started to clip, and then turned it back down a little.
The output I picked a voltage, and set all 6 outputs to that point (making sure I had zero clipping)
Then I moved on to the amps. I set them the same way as everything else (turned the gain up till they clipped, and then turned it down a notch) The only diffrence was I used a 1000 herts -10db track.
Now I am at a loss. There has to be a way to get rid of this noise, I just can't find it.
__________________
JC's Customs
"Taking care of all your car audio and performance needs"
Old 04-01-07   #2
joeyc
joeyc has much to be proud ofjoeyc has much to be proud ofjoeyc has much to be proud ofjoeyc has much to be proud ofjoeyc has much to be proud ofjoeyc has much to be proud ofjoeyc has much to be proud ofjoeyc has much to be proud ofjoeyc has much to be proud ofjoeyc has much to be proud ofjoeyc has much to be proud of
Default
um.........WOOOOOW. I thought you had determined it was the headunit?!
Old 04-01-07   #3
JeremyC's Avatar
Default
Well I thought it was, untill I got it all back in and started playing.
__________________
JC's Customs
Old 04-01-07   #4
Platinum Plus
Bwcad1's Avatar
Bwcad1 has much to be proud ofBwcad1 has much to be proud ofBwcad1 has much to be proud ofBwcad1 has much to be proud ofBwcad1 has much to be proud ofBwcad1 has much to be proud ofBwcad1 has much to be proud ofBwcad1 has much to be proud ofBwcad1 has much to be proud ofBwcad1 has much to be proud ofBwcad1 has much to be proud of
Send a message via AIM to Bwcad1 Send a message via MSN to Bwcad1 Send a message via Skype™ to Bwcad1
Default
I know its coming from my audio control DQS. As soon as I turn it off, or disconnect the RCA wires that go to my amp it goes away.
maybe the dqs is just failing i mean you narrowed it down to this so y not just get another?
__________________
Old 04-01-07   #5
JeremyC's Avatar
Default
Quote:
All ready tried. I just got it back from audio control a few weeks ago. I am going to call them again tommorow, but I don't thank they will have anything new for me to try.
__________________
JC's Customs
Old 04-01-07   #6
Ryan from Ohio's Avatar
Ryan from Ohio This person is "the shit"Ryan from Ohio This person is "the shit"Ryan from Ohio This person is "the shit"Ryan from Ohio This person is "the shit"Ryan from Ohio This person is "the shit"Ryan from Ohio This person is "the shit"Ryan from Ohio This person is "the shit"Ryan from Ohio This person is "the shit"Ryan from Ohio This person is "the shit"Ryan from Ohio This person is "the shit"Ryan from Ohio This person is "the shit"
Send a message via AIM to Ryan from Ohio
Default
Get rid of the DQS and buy something different?
Sounds like every installation issue has been addressed. Only one I can think of is power/ground crossing the RCAs path? Outside of that, sounds like its covered/correct.
Hopefully you have a dealer nearby?
__________________
Old 04-01-07   #7
JeremyC's Avatar
Default
Quote:
They do in a couple places (after the DQS), but I can jumper the wires from RCA to RCA (removing the DQS) and the noise goes away.
Oh and I just switched the input / output for the mids and highs, and it got quieter. So the high input/output is the noisy one. The Mid input/output isn't as bad.
__________________
JC's Customs
Old 04-02-07   #8
The Ancient
cargodz's Avatar
cargodz This person is "the shit"cargodz This person is "the shit"cargodz This person is "the shit"cargodz This person is "the shit"cargodz This person is "the shit"cargodz This person is "the shit"cargodz This person is "the shit"cargodz This person is "the shit"cargodz This person is "the shit"cargodz This person is "the shit"cargodz This person is "the shit"
Default
Definately a problem in the DQS then... as Ryan stated, get rid of it and get something different (I've never been much of a fan of Audio Control... too iffy as you're finding out).
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© Car Audio Central 1999-2009 All Rights Reserved. Information may not be reposted without posters permission.
[Output: 79.28 Kb. compressed to 74.37 Kb. by saving 4.91 Kb. (6.19%)]
