Trending
UMI Strut Tower brace
| Category | Part / mod | Brand | Purchased / Installed by | Notes |
| Suspension | Strut Tower Brace | UMI | UMI Performance | — |
| Suspension | Adjustable Caster Camber Plates | Founders | Founders Performance | — |
Just installed the UMI Strut Tower Brace.
Installation was OK once I realized that it came assembled backwards. I couldn't get the hood to shut. I had to remove the bar and turn it around. It was then centered with the engine, and the hood will shut now.
It's still a tight fit, I wish it sat just a tad bit lower. I think it's pushing right on the hood insulation, but it's shut. So I'll see if there is any wear or anything on either the brace or the insulation.
EDIT: Well it's been installed for a few months now, noticed just a small amount of rubbing on the bar from the insulation. But I think it's been OK. Just wish it sat just a tad bit lower. This bar is meant to be used with a TPI, so not quite sure why they didn't design it to sit maybe ¼ inch lower. Then it wouldn't rub at all, and would look a little better too.
