Adding new carbon fiber handlebar grips
Yamaha R6 (2005) - Haven’t decided
Shadow073180's Avatar
This was super simple, removed the grip ends, the two screws on the starter switch column. I loosened up the throttle line and replaced the grip with the new throttle grip. For the other i exactod the old grip off and put the new one on.
No title-992
After
No title-993
No title-994
Before
Leave Shadow073180 a comment. Utilize the @username feature to efficiently bring other members into the conversation
Build image of LED Under glow lighting
Purchased an LED kit from Amazon for around $50.00, it came with 12 led tubes, a power wire with inline fuse, a negative wire, two remotes, and spare
July 1, 2024
Build image of Finished installing new fairings
Just finished the build , still need some rivets for the tail but you can see what the finished product would look like.
July 7, 2024
Build image of Finishing LEDs
Finishing LEDs
The kits switch went outso i purchased a switch and wired it into the LED circuit after cutting the bad switch out. I ran the wire and installed the s
July 10, 2024
Build image of Making it run
Making it run
I have no idea what the previous owner was thinking , but after diagnosing the starting issue it led me to checking the voltage of the battery with th
June 27, 2024
