Hero image for 18x9 + 30 offset with 1.5 inch wheel adapters. On the radar
Mini Cooper (2007) — Mini Bee
Shadow073180's avatar
Finally got moved into our new house and I have my garage , so the real work can begin. I finished installing my JNC 18x9 +30 with 215/35R18’s and an inch and a half wheel adapter from bolt pattern 4x100 to 5x120. I didn’t know if the turning radius was going to rub but , it is the tightest it can be without rubbing. Next thing is to fabricate my wide body kit out of 18ga steel sheet metal and make it a fender to lip fitment. I still think it looks good as it is now, but it should look amazing when I finish the body kit, put air ride on it and repaint it.
Also the stud bolt heads were too tall to let the two adapter pieces fit together flush so i ground down each stud bolt to be flush with the top part of the bottom piece of the adapter.
2007 Mini Cooper - 18x9 + 30 offset with 1.5 inch wheel adapters. - Image 1
2007 Mini Cooper - 18x9 + 30 offset with 1.5 inch wheel adapters. - Image 2
2007 Mini Cooper - 18x9 + 30 offset with 1.5 inch wheel adapters. - Image 3
2007 Mini Cooper - 18x9 + 30 offset with 1.5 inch wheel adapters. - Image 4
2007 Mini Cooper - 18x9 + 30 offset with 1.5 inch wheel adapters. - Image 5
2007 Mini Cooper - 18x9 + 30 offset with 1.5 inch wheel adapters. - Image 6
