5627 Views Results 1 to 5 of 5
    Six channel Impedance Help
    Started by inetba at 10-10-10, 09:19 PM
    Get Yourself Some OBD2 DIY Tools for Automotive Diagnosis
    Started by Simon55 at 01-11-11, 09:48 AM
  2. Bwcad1
    Reground the Head unit to the frame. What brand HU is it?
    Ground loop isolators hide the issue and typically cause degradation of the output voltage.
    Also having a good ground doesn't mean it wont induce noise. try taking a wire from the HU ground and grounding to the same spot as the amp.
    I can pretty much guarantee a ground loop somewhere as its coming into the reception of the antenna.
  3. CaptainPioneer
    Pioneer avic X910BT. I will re-ground when I have a chance... So just run a wire strait back to the where the amp is wired? I can do that just temporarily and see if anything happens. So you definitely don't think its the power line causing interference with where the antenna line is run right? That would be great to know if its not that... I would hate to have to re-run that line again...
    COR UNUM VIA UNA - Jay Chmura
  4. Bwcad1
    Should have known it was a pioneer... Goodluck! I have never had a problem with power by antenna wires.
  5. CaptainPioneer
    Of course you should have known lol! Yea I think it will be fine once I take a little more time to isolate the problem
  1. Replies: 0
    Last Post: 05-19-10, 11:04 PM
  2. head units with best radio reception
    By raceguy13 in forum Head Units
    Last Post: 04-01-09, 02:28 PM
  3. line noise?
    By MrSo0h0o in forum Car Audio Discussion
    Last Post: 01-21-08, 10:04 AM
  4. Poor AM reception 2004 Hyundai Elantra
    By miker1909 in forum Car Audio Discussion
    Last Post: 10-10-07, 03:48 AM
  5. Bad reception - need help
    By kouger in forum Car Audio Discussion
    Last Post: 12-15-04, 08:14 PM
[Output: 65.87 Kb. compressed to 60.54 Kb. by saving 5.33 Kb. (8.10%)]
