2797 Views Results 1 to 9 of 9
    Where to buy resin and fiberglass..
    Started by tater at 06-30-08, 07:11 PM
    Can we say UNDER RATED.
    Started by JeremyC at 07-03-08, 06:51 AM
  2. Munki
    Member
    07-02-08 #2
    wood: 3/4 MDF
    glue: titebond
    carpet: totally optional
    wood screws, k-claps, wood working tools,ect.
    im not going into demintions because you can go to the website and c the recommended size for a ported kicker <i think>
    its 5am and thats all i can say for now....don't worry im just a n00b so the real guys will be here to help you soon,
  3. Munki
    Member
    07-02-08 #3
    Ok i got bored and i looked up your demintions for you.......ok for a single you need 1.75-2.25 cu. ft.. Seeing as to how you are using the plural form of cvr. i assume you have 2 of them. SO i am by no means a box builder i think you should have a 4 cu ft box.......not too big but not almost suffocating the subs.
    SOMEONE CORRECT ME IF I AM WRONG!!! we are here to help people not to give false information.
  4. Ryan from Ohio
    I would just play around with this till you get what you want out of it:
    http://reaudio.com/speaker_box/LPort_Box_Calc.html
    Just make the cubic feet big enough for both subs, build as shown and cut your holes for the subs.
  5. cargodz
    By the way, coated decking screws work far superior to standard wood or drywall screws.
    [URL="http://www.teamcargodzinc.com"]http://www.teamcargodzinc.com[/URL] :thumbsup
    [SIZE="2"][FONT="Times New Roman"]Hear It, See It, Feel It, Punch It![/FONT][/SIZE]
    [URL="http://www.teamwolfpackaudio.com"][B][I]Team Wolf Pack Audio[/I][/B][/URL]
  6. jgs07
    Quote Originally Posted by Ryan from Ohio
    umm im not sure of what im doing. what do u recommend i put in as the measurements Ryan?
    thanks everyone else for ur input it is very much appreciated.
  7. Ryan from Ohio
    Well...
    Measure up the area you can put the box in. Make sure it will fit thru the trunk, hatch, door, etc.
    Then plug them numbers into that thing in red.
    Next tell it what tuning you want, I would say 34 Hz.
    Next look at the box volume and compare to whats suggested from Kicker. Adjust the size to get the suggested, cut and build.
  8. OnYrMrk
    07-03-08 #8
    Quote Originally Posted by cargodz
    we used Spanner screws, they worked very well. you can't remove them without the correct tool. Excellent safety tip for someone wanting to protect their investment. we used spanners on everything in my car.
    www.cvdaudio.com
  9. Bwcad1
    Deckmate Decking screws
  1. Ported enclosure for 2 SDC2.5s
    By The Bode in forum Car Audio Discussion
    Last Post: 03-29-09, 11:49 AM
  2. L ported enclosure for a 12" BL
    By jgs07 in forum Car Audio Discussion
    Last Post: 03-12-09, 04:32 PM
  3. finished ported enclosure
    Last Post: 08-26-08, 09:50 AM
  4. Ported Enclosure Troubles
    Last Post: 07-05-08, 04:37 AM
  5. Enclosure Building Question
    By Silenkiller in forum Car Audio Discussion
    Last Post: 12-10-05, 09:33 AM
[Output: 77.40 Kb. compressed to 70.35 Kb. by saving 7.05 Kb. (9.11%)]
