Page 1 of 2 12
8066 Views Results 1 to 10 of 11
    Benefits of Colocation
    Started by solacedagony at 10-26-08, 08:34 AM
    Dj speaker's Build
    Started by Bwcad1 at 11-18-08, 01:31 PM
  2. Bwcad1
    Carpet the walls.
  3. Ryan from Ohio
    well the foam blocks with 60 degree triangles seems to work wonders.
    If you did the entire room with it you could scream your heart out and nobody would hear you, probably...
    I did it in an MDF box lined with it. Couldnt hear me outside the box...
  4. William from NOLA
    Vroom!
    11-03-08 #4
    If you wrap up some insulation into sheets and put them over the walls, that might help you a bit.
    I did such except I had them stapled to wooden boards for sound control. I wrapped them in cloth.
    A.K.A. megahurts4 :: Member since: July 19, 2002
  5. falkenbd
    Foam and lead. Lead has a very high mass, foam can help absorb some sound waves.
  6. solacedagony
    I don't think I could get lead in big enough sheets at a cost-effective price to make it work.
    FWIW, I'm not really worried about anything but the low frequencies.
  7. loudwagon15s
    i think a foam covered walls, floors, ceilings would make teh ladies wonder haha
  8. CaptainPioneer
    they do make studio walls but to be honest... that stuff is massively expensive you might be better off with some carpeting on the walls and then some foam over that.
    COR UNUM VIA UNA - Jay Chmura
  9. falkenbd
    i've made those studio walls before. for a portable one, we would build a frame out of 2x2's and put wire in between to staple insulation to, then lay in several layers of quilt batting and cover in burlap or felt. you could probably make some 4x8 panels like this and set them against or hang on the walls.
  10. solacedagony
    Quote Originally Posted by loudwagon15s View Post
    They already wonder. I'm just doing this so when we go in my room, I can close the door and say "You can't escape now..." all creepy like.
    Quote Originally Posted by falkenbd View Post
    That's a good idea, I was thinking of make the walls more 2 dimensional, but a 3 dimensional frame would probably be better so I can use multiple types of sound deadening in there.
Page 1 of 2 12
  1. low frequencies good for your bones
    By neumann in forum Off Topic
    Last Post: 01-09-09, 06:54 PM
  2. multiple tuning frequencies
    By colemanyoungerinalaska in forum Speaker Help
    Last Post: 06-28-07, 12:54 AM
  3. T/S and bass box
    By Darthness in forum Car Audio Discussion
    Last Post: 05-27-06, 07:29 PM
  4. Crossovers, dB's, slope, frequencies... ingles por favor
    By sonso_chi in forum Car Audio Discussion
    Last Post: 05-23-06, 03:29 PM
[Output: 81.08 Kb. compressed to 73.90 Kb. by saving 7.18 Kb. (8.86%)]
