Page 1 of 3 123
14535 Views Results 1 to 10 of 23
    EHQS12 Build
    Started by solacedagony at 01-13-08, 09:23 PM
    av help from the best
    Started by ez28 at 04-23-08, 08:59 PM
  2. William from NOLA
    Vroom!
    03-14-08 #2
    Pretty nice, the only thing that is questionable is the Behringer. I have a bunch of Behringer items and they aren't magnificent, but they work and do a decent job.
    A.K.A. megahurts4 :: Member since: July 19, 2002
  3. solacedagony
    Quote Originally Posted by William from NOLA
    Yea, I've heard odd stories of the DCX randomly not working or having noise problems. This is why I got a 2-year warranty on it, besides the standard warranty. But there simply isn't anything in that price range with the features the DCX has, so it's worth it to me. The dcx driverack is more, I think, in the $600-$700 range. That's as much as half my setup
  4. Jonathan
    Let us know how it sounds. I've heard the kit before, it's very impressive considering the price. I built the Waveguide TMM project but ended up giving it to a friend. Sounded really nice.
  5. solacedagony
    Quote Originally Posted by Jonathan
    I surely will post updates on the work and my impressions of the sound. I need to wait til Monday to hook anything up, because I was stupid and ordered male XLRs and no female XLRs
    I was looking at the waveguide and the new 3.5 way as possible future projects.
  6. solacedagony
    Got as much work done on one of the cabinets as I could before I ran out of MDF. I probably won't get anymore done at least until the end of this week when I can pick up more MDF and actually have some time.
    I'll be first to say that I'm not the best wood worker around here, so any criticism is welcome. I really need to get myself a table saw. I think that would eliminate a lot of problems. Because I can't cut straight with a circular saw.
    2933673150087747380MrnMcg th
    2322156110087747380ViaPSx th
    2206130400087747380RIVZlD th
    2434706800087747380vscuwS th
    2147045710087747380QlBbnl th
    2871882420087747380Htyslk th
    2522008640087747380NkbQyZ th
    2393913450087747380ctJgig th
    2573734190087747380aTfeFE th
    2277935090087747380ViEHcv th
    2944618640087747380hzggQS th
  7. solacedagony
    Got a couple more updates on the Webshots. Got both boxes done, but I realized I cut one of the baffles backwards, so I gotta get that baffle back off and put a new one on. Got pics of the crossovers. Also got pics of the DIY cables I made up. TRS 1/4" to XLR and XLR to XLR, all balanced cables.
  8. Ryan from Ohio
    I dont have a table saw either. But I sure do have a piece of 1 1/2" Aluminum angle iron and 2 clamps that allow me to cut straight.
    I have access to a table saw when I really need one. Which was the case with that box that had a triple front baffle.
  9. solacedagony
    Quote Originally Posted by Ryan from Ohio
    The biggest piece of angle aluminum that I could find at Home Depot was like 1/2" or that is what I was going to do. I'm going to have to go over to Lowes and see if they have anything bigger.
    For the baffles/rear panels, I cut them like 1/2" too long/wide and just routered them even with a pattern bit. Makes perfect baffles even if your box isn't perfectly square.
  10. Bwcad1
    Aluminum angle can warp and bend out of shape over time especially if set on its end. get yourself a good 4ft level for about 30 bucks and you should be golden. another tool i strongly reccomend is a good belt sander. even if your not the best with a table saw or a circ saw the belt sander comes in handy. my inside cuts are the only ones i worry about being 100 percent straight the rest i cut an 1/8th heavy and then sand with my angle grinder with 24grit and finish it up with 80 and 120 on the belt sander.
Page 1 of 3 123
  1. 8w7 setup
    By Nomade30 in forum Speaker Help
    Last Post: 08-21-07, 11:50 PM
  2. here is my new setup
    By woody88 in forum Install Show Off
    Last Post: 06-23-06, 03:00 AM
  3. My new setup
    By sinister audio in forum Install Show Off
    Last Post: 08-10-05, 08:51 AM
  4. What Was Your First Setup?
    By Harrison486 in forum Car Audio Discussion
    Last Post: 05-02-05, 07:18 PM
[Output: 93.13 Kb. compressed to 85.83 Kb. by saving 7.30 Kb. (7.84%)]
