Likes Likes:  5
Page 3 of 4 1234
92144 Views Results 21 to 30 of 40
  1. Chris from Washington
    03-12-12 #21
    Mr. LED is at it again!
    My latest retro was the instrument cluster on the Camaro. From the factory it only has 4 bulbs that light up the whole cluster, so it was very dim. So dim, you couldn't even read the odometer at night.
    So with this retro, I went with using LED strips and placed them where it would give me the best light for each gauge.
    LED strips
    and here are the before and after pictures.
    Before: cluster old
    After: LEDgauges 2
    I'm very pleased with how this turned out, I have a little tweaking still to do. The oil pressure gauge has a little bit of a hotspot, I might need to move a strip around some.
    I would also like the get the needles to light up more, so I'll need to add a few more LEDs around that area too.
    but being able to actually see the numbers is cool!
  2. Purple RS
    I like. I don't remember mine ever being that dim on my 92, but the LED strips make a huge difference. Gives me an idea for the 89, though different application - maybe some side-firing strips attached to the inside of the metal bezel (gauges are front lit by reflection off the bezel).
  3. Chris from Washington
    03-12-12 #23
    Quote Originally Posted by Purple RS View Post
    ya since those gauges are not back lit, some side emitting LEDs would look good in there. I got my strips from SuperbrightLEDs and they do have the side firing strips too.
  4. Chris from Washington
    06-05-13 #24
    Update: 6/5/13
    Been working on the audio over the last few months, finally got the subs installed.
    Built a fiberglass box to fit the well, had to go a bit higher than I wanted to allow clearance for the motors of the subs. So I made a cover that blends the floor and the box together.
    2 Image Dynamics IDQ12v3s powered by an MMATS 1400.1
    84 Camaro Restoration
  5. MobileAudio219
    I like the 3rd gens WHEN they are done up right... Like the foxes, most of them are all ragged up by now.
    [URL="www.projectcarforum.com"]www.projectcarforum.com[/URL]
    [SIGPIC][/SIGPIC]
  6. Chris from Washington
    06-14-13 #26
    Quote Originally Posted by MobileAudio219 View Post
    Ya F-Body's and Foxes sure do seem to get the wrong owners in so many cases, and they just get destroyed.
    But I guess the good thing, that means ours become more valuable.
    I sure have noticed, I don't see as many 3rd gens on the road anymore. Actually vary rarely now.
  7. mbober99
    Default Re: 84 Camaro Restoration
    [QUOTE=Chris from Washington;140067]Update: 6/5/13
    Very nice car Chris! Love the front ends on that generation camaro. Very nice IDQ setup in the back too, i wanted to use the same subs but i let someone talk me into two 15" Type R subs. Its turning into alot of work to get them to fit so its a slow project...lol. What else you using for audio in there?
    Sent from my Nexus 5 using Tapatalk
  8. Chris from Washington
    06-08-14 #28
    [QUOTE=mbober99;140655]
    Quote Originally Posted by Chris from Washington View Post
    Update: 6/5/13
    I just got done building new kickpods, here is a thread on that here.
    and installed a PPI 600.2 to run them.
    Next year, I'm going to convert the 1.5 DIN stereo opening to double din, and install a touch screen type unit in there. That's going to be tough, but I've seen others do it. So I know it can be done.
  9. latoya0511
    Member
    07-19-14 #29
    I love that color. I think your restoration turned out great. What else are you going to do to it?
  10. Chris from Washington
    07-19-14 #30
    Quote Originally Posted by latoya0511 View Post
    My next project, most likely next Spring will be converting the single din size stereo opening to a double din size.
    Then next will be finishing the interior, getting the seats done in leather, then wheels stuff like that.
Page 3 of 4 1234
  1. Help me win Camaro of the Month!
    By Chris from Washington in forum Off Topic
    Last Post: 05-17-12, 04:40 PM
  2. Some other toys for the Camaro
    By Purple RS in forum Off Topic
    Last Post: 08-22-07, 03:09 PM
  3. thinking about this for the Camaro
    Last Post: 08-19-07, 08:23 PM
  4. Anyone ever seen a double din in a Camaro?
    By Chris from Washington in forum Car Audio Discussion
    Last Post: 01-08-07, 08:29 PM
  5. two 15"s+Camaro=cool
    By Scarrell in forum Install Show Off
    Last Post: 07-05-06, 01:12 PM
[Output: 82.00 Kb. compressed to 74.94 Kb. by saving 7.06 Kb. (8.61%)]
