2773 Views Results 1 to 3 of 3
    mielno
    Started by unaxsersuak at 03-09-11, 01:51 PM
    sarbinowo
    Started by IconeeVineact at 03-09-11, 11:31 PM
  2. William from NOLA
    Vroom!
    03-10-11 #2
    That is weird. Check the specs on the battery and see if it is the same as the one it replaced. I'm assuming it can't supply that initial "cranking amps" to get it going. I would try running it all the way down and allowing it to recharge. If that doesn't do it, I would return the battery for another.
    A.K.A. megahurts4 :: Member since: July 19, 2002
  3. Ryan from Ohio
    I will give that a try also.
    On another board the one guy thinks something in the charging circuit is messed up- possibly corroded from a spilled drink. This weekend Im gonna open her up and see if I can spot any corrosion. Also going to clean it out or dust.
  1. Opinions on this Laptop?
    By NorthQuad in forum Off Topic
    Last Post: 08-18-09, 12:33 PM
  2. laptop
    By smoker in forum Off Topic
    Last Post: 04-13-08, 11:21 AM
[Output: 52.67 Kb. compressed to 48.43 Kb. by saving 4.23 Kb. (8.04%)]
