5954 Views Results 1 to 9 of 9
    Online Car Parts Store?
    Started by audiocr381ve at 12-05-09, 02:27 PM
    door handles/lock mechanisms keep freezing!
    Started by MobileAudio219 at 02-10-10, 06:44 AM
  2. MobileAudio219
    Sounds like a blown fuse to me...
    I'm not sure on the speedometer and odometer, I'm not a honda person.
  3. Bwcad1
    Are they out completely or working sporadically?
    If there out completely and you saw sparks you blew a fuse. If there working intermittently you have a bad connection somewhere.
  4. audiocr381ve
    They are working sporadically. I will check fuses and holler back. I'm hoping it's a fuse!
  5. MobileAudio219
    It's probably not a fuse then, unless it's about to fall out or something... Probably a loose connection somewhere..
  6. smoker
    hmm....seen this before, go to the junkyard and get yourself a new instrument cluster. those honda instrument clusters are pretty crappy and if your not careful they destroy very easily. another installer at a shop i used to work for ruined one in a guys car one time because he caused a wire to arc when installing a head unit
  7. audiocr381ve
    Smoker, what exactly happens when a wire arcs?
  8. smoker
    depends i guess. its the term i use to refer to "making sparks" it can happen when something gets grounded or when you connect power wires that are "live" or god forbid you ground a power wire or hook a ground wire to power
  9. audiocr381ve
    My sound system went out as well. Amp isn't turning on. Hmm, can someone give me another hypothesis?
    Again, I was just messing with the Cigarette Lighter trying to get it to work again. Saw some sparks and that's when the problems happened (speedometer, odometer, sound system).
    The head unit actually turns on too. Amp doesn't. Check power wire fuse and it looks good. Check ground and that's good. Checked remote wire and that's good.
  1. A million miles on the odometer
    By nist7 in forum Off Topic
    Last Post: 03-20-05, 09:36 PM
[Output: 71.86 Kb. compressed to 65.61 Kb. by saving 6.25 Kb. (8.70%)]
