Page 2 of 2 12
12738 Views Results 11 to 14 of 14
  1. Purple RS
    A little more work this weekend. This in preparation for T56 transmission in the near (or not so near) future. From a friend, I acquired a scatter-shield (bell housing) and T56 adapter plate to mount to the rear of the motor. Probably overkill for now, but it will make the six-speed swap so much easier when the time comes. The scatter-shield I can use right away, but the adapter plate will have to wait for the T56. The setup will allow me to use an LS1 T56 and still use my 3rd-gen clutch, pedals, and hydraulics, all I need is an extended pilot bushing (the adapter is 1/2" thick so effectively shortens the input shaft), a new transmission cross-member for the T56, and shorten the drive-line.
    Of course the swap did not go as planned...
    First, we found out that my builder drove the transmission alignment dowels too far into the block, so aligning the scatter-shield was a challenge. We did the best we could, but since my input shaft had a small amount of play, we went with what we had. Also, my friend didn't tell me that the stock trans-to-bell bolts wouldn't work for the scatter-shield, we spent nearly an hour looking through every bin in the shop for some bolts I could use until I replace them with some more correct graded bolts.
    Here is where we were attempting to align the bell, a dial indicator will go on that shaft...
    It's time for motor upgrade
    Finished and ready to install the transmission...
    Just a few bolts to tighten...
  2. Chris from Washington
    03-12-12 #12
    Quote Originally Posted by Purple RS View Post
    This is all the stuff I know nothing about lol, but looks like you're making progress on it!!
    Having a shop to work in sounds nice too!
  3. Purple RS
    Shop belongs to a friend By the time we were finishing up, I was thinking I might be staying the night. We finished up about 10:30pm and I was home just after 11:30 - he's a good 60 miles away...
    BTW, I'm still learning as I go too.
  4. Purple RS
    This weekend, I was able to dyno this motor. As far as I know, except for the crank, rods and pistons (which make it the 383 it is), all the internals of the motor are stock 350 parts. I need to do a bit more tuning, but I got some good power and torque to the rear wheels...
    248 hp @ 4400 rpm
    348 lb/ft @ 3200 rpm
Page 2 of 2 12
  1. motor vibration causing skipping
    By Gibson5469 in forum Head Units
    Last Post: 03-17-07, 08:00 AM
  2. motor city reman
    By Darthness in forum Car Audio Discussion
    Last Post: 02-10-07, 10:21 AM
  3. upgrade time...woohoo!!
    By joeyc in forum Car Audio Discussion
    Last Post: 11-26-06, 10:53 PM
  4. Upgrade Time!
    By Jszar in forum Car Audio Discussion
    Last Post: 01-09-06, 10:33 PM
  5. Replies: 4
    Last Post: 03-18-05, 10:49 PM
[Output: 58.33 Kb. compressed to 54.03 Kb. by saving 4.30 Kb. (7.38%)]
