Page 1 of 2 12
2939 Views Results 1 to 10 of 14
    Alpine type s or type r 6.5s/ comps or coax?
    Started by Mithrandir at 12-18-05, 11:50 AM
    how does this look
    Started by veggie-man at 12-22-05, 08:43 PM
  2. Bwcad1
    havnet been a big fan of there stuff one of the installs i did the guy used one of the blaupunt hu's and we ended up pulling it out 2 weeks later, becasue it wasnt as "good as his friends"
  3. OnYrMrk
    12-21-05 #3
    Heard a Velocity 10...sounded like ass
    www.cvdaudio.com
  4. stephensmia
    Hey guys heres the system I might be buying what do you think
    Components
    Blaupunkt Vc 540
    Size 5.25"
    Type 2 way
    Power Continuous (W rms) 100
    Power Peak (W max) 200
    Sensitivity (dB 2.83V / 1m) 90
    Frequency Response (Hz) 70 - 23,000
    Magnet Weight (oz) 11.3
    Cone Material Silk
    Surround Material Rubber
    Mounting Depth (in. / mm) N/A
    Component amp
    Blaupunkt PCA 260
    Channels 2/1
    Unbridged Power (Wrms) 2 x 60
    Bridged Power (Wrms) 1 x 150
    Load Stability unbridged 2ohm @ 2x80W
    bridged 4ohm @ 1x150W
    S/N Ratio: dBa @ 1W >80
    dBa @ Full Power >97
    Input Mode RCA
    Input Gain Range (V rms) 0.3 - 6.0
    Crossovers HP/LP, 50 - 250
    Dimensions (in) 1.9 x 10 x 8.5
    Sub
    Bluapunkt Vw 1200
    Size 12"
    Type 2 Ohm DVC
    Power Continuous (W rms) 1200
    Power Peak (W max) 2400
    Frequency Response (Hz) 20 - 200
    Magnet Weight (oz) 80.0
    Cone Material Woven Fiber
    Mounting Depth (in. / mm) 6.14 / 156.0
    Sub Amp
    Blaupunkt VA2200
    Channels 2 / 1
    Unbridge Power (Wrms) 2 x 200
    Bridged Power (Wrms) 1 x 600
    Load Stability bridged 4 Ohm @1x600W
    bridged 2 Ohm @1x650W
    S/N Ratio dBa @ 1W >80
    dBa @ Full Power >100
    Input Mode RCA
    Input Gain Range (V rms) 0.3 - 8.0
    Crossovers HP/LP 50-250
    Dimensions (in.) 2.4 x 11.8 x 19.3
  5. Bwcad1
    sticken with blaupnkt huh? well i have no comments then other than i think your going to be disapointed
  6. stephensmia
    I'm getting the whole system for $500
  7. smoker
    for about 6 bills or so i could hook you up better than that......of course im not in germany.......
    i could get you one of two different 4 channel amps from elevation audio(399.00) an elevation audio comp 12(99.00) and a set of scosche 5 1/4 comps (85.00) (they sound pretty good just lacking some midbass) or elevation audio 5 1/4 coax's (89.00)
    now granted these are our grand opening blockbuster cant be beat anywhere sale prices on some of it but you should be able to get this stuff or similar products for close to that.....
  8. smoker
    oh and it would be a hell of a lot more power too......
  9. stephensmia
    that sounds good. but the thing is that blaupunkt is sponsoring me and this could lead to better companies giving me stuff. I get anything I want from them at a very low cost. I'm open to what you guys say so before I throw away a sponsor tell me is blaupunkt just crap or are they decent
  10. audiobass10
    How did you get Blaupunkt to sponser you?
Page 1 of 2 12
  1. OPEL ASTRA GTC - blaupunkt demo - SLO
    By LBaudio in forum Install Show Off
    Last Post: 04-01-08, 05:29 AM
  2. Blaupunkt sacramento cd33
    By RegetoneCabrone in forum Head Units
    Last Post: 09-28-06, 11:03 AM
  3. any of you guys with shops sell primier or blaupunkt?
    By diceman1000 in forum Car Audio Discussion
    Last Post: 11-26-05, 04:41 PM
  4. how bad are blaupunkt speakers??
    By churchbouy in forum Car Audio Discussion
    Last Post: 05-13-05, 03:48 PM
[Output: 80.64 Kb. compressed to 73.52 Kb. by saving 7.12 Kb. (8.83%)]
