My DREAM build
nathansadkins
My DREAM build
Post by nathansadkins »
I recently purchased a Pioneer MVH-X380BT and installed it in the metra dash kit for my 2003 Honda Accord 4cyl. I am planning to do a full audio overhaul in my car and would love some advice on my plans.
1.)2 Kicker 40CS654 CS65 6.5s (100 watts RMS each)
-https://www.amazon.com/dp/B00B9H8L4K/re ... dyb9PCZCJA
2.) 2 JBL GTO938 6x9s (150 watts RMS each)
-https://www.amazon.com/dp/B003KN2TGM/re ... dybCSQ3250
3.) 2 SoundQubed HDS208-D2 600W RMS 2.5" Coil -https://www.amazon.com/dp/B00TA2WW3M/re ... dybYK4X02N
4.) 1 Hifonics BRX616.4 Brutus 4-Channel Super Class-A/B Amplifier, 640-Watt (for the front speakers) -https://www.amazon.com/dp/B00T3VMV2W/re ... dyb5924FYG
5.)1 Hifonics BRX1616.4 Brutus 4-Channel Super Class-A/B Amplifier, 1600-Watt (to power the subs) -https://www.amazon.com/dp/B00T3VMUW8/re ... dybSDVFEWT
So my question is, is this even possible? Can I get this much power from my car? I obviously will upgrade the wire gauge. I know this might be excessive but audio is a part of my life and I want to be bumpin big time. Any type of advice or comments would help me a lot due to this being my first audio overhaul in my car. I've attached links to each items Amazon page for convenience. Thanks for any advice.
Sent from my Nexus 5X using Tapatalk
Re: My DREAM build
nathansadkins wrote:I recently purchased a Pioneer MVH-X380BT and installed it in the metra dash kit for my 2003 Honda Accord 4cyl. I am planning to do a full audio overhaul in my car and would love some advice on my plans.
Sounds like it's going to be a nice system.
How much power does your stock alternator put out? For sure do the big 3 upgrade on your wiring.
The amp is a 4 channel amp, looks like you're going to only have 2 subs? How were you planning on wiring those up?
My concern would be the output of your alternator and the power demands of the amps?
You could always look at a class D amp for your subs, more efficient. People say they are not as 'clean' as class A/B for subs I don't think you'll notice any difference in sound quality.
I have a MMATS 1400.1 running off the stock alt on my Camaro and have no issues with lights dimming etc.
nathansadkins
Re: My DREAM build
Chris from Washington wrote:Sounds like it's going to be a nice system.
Stock alternator puts out 110 amperes. I think the big three will be needed plus maybe wiring up a second battery. I was planning on the 4 channel amp up front and then working a second amp in the back just for the subs
Re: My DREAM build
nathansadkins wrote:Stock alternator puts out 110 amperes. I think the big three will be needed plus maybe wiring up a second battery. I was planning on the 4 channel amp up front and then working a second amp in the back just for the subs
a second battery is just going to cause more of a load on your charging system. Don't do that, unless you really need more engine off time.
Maybe I missed read the specs on the sub amp you listed, but I thought it said it was a 4 channel too.
nathansadkins
Re: My DREAM build
I must of accidentally listed that instead of the one I wanted.
