arc kar 10 or 12
neumann
Post by neumann »
ok thanks for all the input, i think ill go with the arc if i can find one.
Post by High Society »
You should also look into image dynamics, IDQ's would be great for you too.
neumann
Post by neumann »
im likeing what im seeing with the idq. the only problem is that is twice as much as the kar. what would you do, buy the kar for 80$ or the idq for 160$? is the idq that much better for 80$ more?
The IDQ's are the same as the Arc series I believe. My sister was using the arc series 10's (same as the idq's) and they got loud, and sounded great. But you could just go with two Kars. It's really up to you. You most should be happy with either one.
neumann
Post by neumann »
i think im going to go with the kar series because its the only arc's that i can find online. The problem is that they are on acaraudio.com and i have heard some bad things about them. The Kar 10 is only 80$, so i think im going to take the risk.
