can i solder this?
tx_vw_bug_man
can i solder this?
Post by tx_vw_bug_man »
the braded wire from my subs terminal to the voice coil broke can i just solder it back together? what might have caused this?
spear is arc audio arc 15 D4 with a pioneer 1000w D series amp
thanks
andrew
yes you can solder the "tinsel leads" and usually its caused by the woofer exceding its xmax.
tx_vw_bug_man
is there a way to prevent this from happening again? limiting the xmax?
to home depot i go to get an iron
andrew
what kind of box is it in?
tx_vw_bug_man
2.5 cuft sealed box duel voice coil wired +power with jumper to the other + and -power to the other side with a jumper to the - other voice coil
thanks andrew
turn down your gain.
Scarrell
Post by Scarrell »
what were you doing when the sub did this? were you playing it at high volumes? playing test tones? etc...maybe your box is a tad too big.
tx_vw_bug_man
the speaker wants 3 cuft fopr sealed so its actually on the small side
i was jammin out just left a bad day at work but it wasint louder than i normally jam 22 of 50 on my deck volume the speaker is supposed to peak at 1500 my cheap ass amp i know cant even hit the 750 rms the speaker wants but i was jammin out and i got a phone call and turned my deck off to talk on the phone then i turned it back on and there was no sub
i was listening to fat pat a lil bump but not crazy
thanks
andrew
Jammin at 22 of 50? Your gain might be a little high.
Don't pay attention to peak. Those numbers suck. What is the speakers RMS rating?
tx_vw_bug_man
750 rms
http://www.arcaudio.com/arc-05/subwoofers/arc_15d4.htm thats the link to the sub after looking at it i got my numbers mixed up it wants 3cuft ported 2.25 sealed so box sixe could be an issue
thanks
andrew
