is it worth the extra $$$???
ok so my initial setup was 2 10" SWR-1022D type R's with the alpine MRD M1005 amp powering them. now is it worth the extra $200 to upgrade the amp and get the Alpine PDX-1.1000?? if its gonna make a big difference then its a done deal seen as i got a little extra cash for xmas!!
if its worth it do i still get the 1022D subs or the 1042D subs? 2 ohm and 4 ohm is the difference i believe.
thanks for the help/advice
brtnboarder3241
no you don't.
you can wire as many subs as you want to a mono amp, as long as the amp supports the ohm load.. if his amp is 1 ohm stable and he has 2 dual 4ohm subs (for example), that'd be perfect. the number of channels has nothing to do with the number of speakers... its the impedence of the amp and subs..
brtnboarder3241
brtnboarder3241
brtnboarder3241
brtnboarder3241
so just to finalize this, for this amp http://www.sonicelectronix.com/item_3732.html
ill need to run the 2 ohm version of the type R's correct?
o just a side question will this capacitor work really good or is there another i should be looking at? Rockford Fosgate CPCD10-03 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17297
