new speakers
SACHEL
Post by SACHEL »
what im lookin at for the front component speakers are the infinit kappas.
http://www.crutchfield.com/S-uI8UMUqIuw ... I=108607CS
but i still cant find any midranges that are 6x9. if anyone can help, it would be greatly appreciated.
tell you what.
I got a set of Rainbow Made Arc Audio goodness I will let you steal from me for $175...
They are 5.25" set and they will kick the shit out of them kappas on EVERY front ;)
You'd definately do better with the Arcs from Ryan... far superior ;)
As for the back... why not look into putting 6" midbass back there as replacement for the 6x9"s?
[quote="cargodz"]You'd definately do better with the Arcs from Ryan... far superior ]
Or scrap the rears and get the front stage right first :thumbsup
SACHEL
Post by SACHEL »
ha, i would take those arc audios but making those fit in 6 3/4" would take a while.
how can i make 6" midbasses fit in the 6x9?
breakjunki
Post by breakjunki »
actually with a $5 sheet of thin abs you could cut a adapter plate to fit in no time, problem solved. the difference between coaxials and components is amazing. I had to do the same thing, make aq trim plate for 5.25 to 6.5. easy
solacedagony wrote:Or scrap the rears and get the front stage right first :thumbsup
True... You could go without entirely and probably wouldn't even notice :)
SACHEL wrote:ha, i would take those arc audios but making those fit in 6 3/4" would take a while.
I'd personally make baffles out of MDF because it'll be less resonant than plastic. Just figure out what size you need the MDF baffle to be in order to bolt onto the door panel and then cut a circle out in the middle of the MDF. Mount the 6 1/2"er in there. Then try a couple different locations for tweeters to see where they sound best and mount them there.
