Best Components/Coaxials for my setup
Post by audiobass10 »
ProjectVenge97 wrote:Would this Amp work with a set of 6.5" Component 2-Way Speakers for the fronts, and my rear 6X9's?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5864834568&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
Here are the 6X9's I have in the car now: http://www.crutchfield.com/S-QI0jC5gqYy ... 8&banner=1
Is there anything else I need?
You need to pick out speakers before you decide which amp to buy. I'd still ditch the 6x9's as well.
Scarrell
Post by Scarrell »
heres what you could do.. get the amp to power the components and speakers...install it and listen to it... if you Are satisfied and have listened to them thoroughly with every type of music you listen too..etc.. then keep it.. if not then replace whatever you think needs replacing.. if you Want to use rear fill, then get another set of components in the rears.. the overall sound will be alot better than using coaxial speakers, but you could also see how it sounds with just a front stage.. the only way to see what you like is to try it.. so go for it and go from there. :cheers:
brentbarrie
Post by brentbarrie »
Thanks guys. Ive decided to just keep the speakers that I have now, 300w Kenwood eXcelon KFC-X698 & Cadence ZX-6KIT. I want to solve the problem with my lights dimming first and FatMat my car, then Ill look into new 6.5's components and 6X9 coaxials and Amp. I have aftermarket ones in there now, so its not like Im running stock.
