what amp should i use?
Terry is correct my mistake. they were orginally supposed to be dual 1. since you have dual 2s you need an amp that does 2000-5000 at 2 ohm or .5. i would look at the autotek MM4000.1 because its a dual mono block and u can run each side at 1 ohm and get gobs of power from it. this is my reccomendation. i run 2 of them in my buick. and i absolutly love them. i cant think of any other amp that would fit the situation as well.
Autotek MM4000.1 would be the best overall bet for the subs... and like previously stated, ditch the cap and upgrade to a better alt and secondary battery.
I'm sure they were just tryin to get an additional sale out of you by selling you the cap... You wanna run a cap on a system that is sitting right on the boarder of power usage... fine, but they really aren't doing you any good if you're still overworking your stock alt.
