box for a munki
whta kind of car is that? you may get better results with the port facing the rear....
Munki
Post by Munki »
smoker wrote:whta kind of car is that? you may get better results with the port facing the rear....
Its a 1971 ford pinto.. :D but when we g to get this metered we will experiment with it, but the whole reason it was built that way was for the port to be within the seats.
pintos are the shit.....i been wanting one for a while. i think it will probably be a hair louder pointed back though. but only one way to find out for sure...
Don't put your blinker on
falkenbd
Post by falkenbd »
Whats with the first picture of the threaded rod with nuts and washers?
Box looks nice, do you have a pic of it finished?
tater
Post by tater »
finished.
the threaded rod and nuts are the terminals. munki didnt want the wire running through the port. so i just used those.
Tim
Post by Tim »
box looks good, bro. I like the way you smoothed out the outside edges of the port. Not bad
Tim
NorthQuad
Post by NorthQuad »
The bolts are actually a pretty good idea. As long as the metal is a good conductor. But I have no idea about that.
tater
Post by tater »
I havent seen a big problem with them. Its just what i had laying around. if you decide to do the same thing i highly suggest finding a place that sells copper threaded rods, etc. I dont like having a static amount of wire. I never liked the idea of running a hole through the box for the wire
NorthQuad
Post by NorthQuad »
I use one of these badboys.
