failed system restore?
see the thing is, it will come on in stints. before it was on for a good 3 mins before it shut down, so then the mobo is technically ok, no?
it most definitely isnt the psu b/c i just replaced it and before it worked perfectly fine..
ram is fine b/c i used it in my computer..
only other thing i have not tried out yet is the case itself. is it possible though? that the power switch or something like that is faulty?
Ranger SVO
- Member
Its F11 and all 05 Dells have that feature. Mines a top of the line 04 and it has it.William from NOLA wrote:Ditto. System Restore is aweful. The only "system restore" type thing that I've seen, that is good, is Dell's. They actually have a hidden partition on the hard drive with all of your computer's original programming. You can access it when you start the computer with one of the F keys. This is only on the newest Dell's (within the last 6 months I believe).
Ranger SVO
- Member
I had a problem with mine last year and tech support thought it was something that I installed and they had me do a system restore. My 8400 has a production date of December 04.
And by the way, tech support was wrong, it was a problem with the ROM drive (which is what I told them in the first place.)
