Help with WinISD, RE SE 12" box :(
Post by audiobass10 »
Lv=2.35625x10^4D^2vNv/Vbfb^2-kDv
Or You can just use winisd's port calculator heh.
chodecz
Post by chodecz »
Ok, found a box spec in a manual for a JL 12w7 subwoofer.
RE Audio recommend a box 1.8cuft tuned to 32hz for my SE 12" sub.
Check the box spec here:
http://homepage.ntlworld.com/con2000/sub_box.JPG
It's a 1.75cuft net volume box, with a speaker displacement of 0.14cuft, compared to my SE which is 0.15cuft. So the tuning will be at a slightly lower with my SE in it.
Do you think this box would be fine for my RE SE?? The box spec seems a nice blueprint to build off (without me having to do all the hard work, lol).
Also, the spec has a 1" MDF front baffle, is this enough for the RE SE, or should I double baffle (1.5")???
*EDIT* Or better still, does anyone have a blueprint for a RE SE 12" sub enclosure???
chodecz
Post by chodecz »
Bump.... guys I know i'm a dumba**, but anyone out there willing to help me??
i can make a blue print for you later on today if you want but i dont have time to do it now.
chodecz
Post by chodecz »
I would VERY much appreciate this, and would be forever in your debt! :)
http://www.bcae1.com has all the calculators for box design as well if you want to play with them yourself while you wait.
Darthness
Post by Darthness »
reaudio.com has boxplans for their subs.
- Keith
chodecz
Post by chodecz »
Darthness - not for the box size i want.
I have played around the the BCAE calculator, and got varied results. For example I want to try to replicate the specs of a JL Audio slot port box for a 12w7 sub, using the BCAE calculator.
Heres the JL box spec from the manual...
Heres what I put into the BCAE calculator to try and replicate the spec of JL..
http://homepage.ntlworld.com/con2000/bcae_cal.JPG
There will be a minor difference due to the front baffle on the JL spec being 1" instead of 0.75". BUT, the JL manual has a slot length of 24", and the BCAE calculator has 31.028 slot length!?
I just wanna make sure the BCAE calculator is acurate for a slot port.
here you go try this its 16HX27.5WX12D
Box Parts (Square Prism)
1 Top, 1 Bottom: 12 (c) x 25.25 (b) in
0.75 (thick) in
1 Front, 1 Back: 14.5 (a) x 23.75 (d) in
0.75 (thick) in
2 Sides: 14.5 (a) x 12 (c) x 0.75 (thick) in
Vent Parts
1 Top, 1 Bottom: 3 (e) x 21.68 (h) in
0.75 (thick) in
2 Sides: 10 (g) x 21.68 (h) x 0.75 (thick) in
see if that will fit in your car and if it does there is the cut list
chodecz
Post by chodecz »
Yes, these dimensions will fit my car. Thankyou for your help! Please continue..
