wire harness for my 02 bonny
Tim
Post by Tim »
Ok dudes, I am O-fficially confused. Got mah new head unit right?? Pioneer Premier P980BT. Okay the place I got if from sent me a dash kit and the harness to hook it up(free). Not Crutchfield either.
I just got to looking at the harness and it has six (6) brown wires, five of which are labeled mute, three (3) black wires, all of which are labeled ground, two (2) yellow wires, all of which are labled 12+ constant. And no remote turn on wire ( blue w/white stripe).
I have the harness from my old deck, so I can use it to wire my new one, so its no big deal really. I am just wondering what is up.
FWIW all the other speaker wires are correct. This is just new to me, did somehting change in color coding I dont know about??
Thanks,
Tim
Tim Strong
Email: [email protected]
X-box Live Gamertag:quad drpr
Im assuming your talking about the harness between the stock and the new deck?
Sounds like they may have added some power and grounds in empty spaces on the plug?
Compare the new plug to the old.
Tim
Post by Tim »
Ryan from Ohio wrote:Im assuming your talking about the harness between the stock and the new deck?
You assume correct on the harness.
It just flipped my lid to see so many wires of the same coding and polarity.
and yet no turn on wire for the amp.
Thanks Ryan,
Tim
Tim Strong
Well I never run the remote turn on into those harness's anyhow... I just wire direct off the HUs harness at that point.
Tim
Post by Tim »
Ryan from Ohio wrote:Well I never run the remote turn on into those harness's anyhow... I just wire direct off the HUs harness at that point.
Yeah so do I, like I said it just threw me for a loop not seein one.
Tim
Tim Strong
that harness will cover a ton of vehicles, ive seen them like that, usually those vehicles will have options from the factory that may not be on your car...
Tim
Post by Tim »
smoker wrote:that harness will cover a ton of vehicles, ive seen them like that, usually those vehicles will have options from the factory that may not be on your car...
so the individual that has a harness like this can just use the wires they need and leave the rest blank...is that correct??
Tim
Tim Strong
