Q-logic Q-forms - Who here uses them?
71buickfreak
Its been a while since I have been on here. Been busy writing. I have a new car audio book coming out, I will let you guys know when it hits the shelves.
I have been doing some blogging for Q-logic. You guys should check it out and send your friends. Make sure you comment.
http://www.qlogicenclosures.com/blog
This is a no BS deal, some may agree, some won't. leave a comment.
Anyway, I have been tapped by Q-logic to do some more kickpanel designs (I used to be the plastics designer when they were owned by Rockford). What would you guys like to see?
We have made some needed changes to the product line, kickpanels are now available in C-series, which means that they don't come with a grill recess, allowing you to install up to a 7-1/2" (OD) woofer. The plastic is much thicker now too. They used to be made from .140" plastic, now they are .180" and strong as hell. They don't flex and the resonance is much lower.
Any suggestions?
Any suggestions?
71buickfreak
Purple RS
I have a set in my F-body (92 Camaro) that have been there for years. Only thing I dislike about them is how far they protrude from the kick panel, especially since I have a 5-speed and need the room next to the clutch pedal. I have grown used to putting my left foot to the front edge of the seat though.
I had a set for the Alero. They were the recessed kind... There wasnt enough depth and also the mounting was kind of bad IMO.
But in defense the Alero doesnt have poop for leg room and it intrudes that little space anyhow...
