kicker
RMS Power Range : 90 Watts
Peak Power Handling: 180 Watts
Impedance: 4 ohms
Perfect Replacement for Factory Speakers
Metallic-Blue Woofer Cones
1/2" Tweeter
Frequency response: 30-21000 Hz
Sensitivity: 92 dB
Diameter: 6x9 Inch
focal
164x235mm (6x9") 2-way coaxial.
32mm (1-1/4") v.coil,
90mm (3-1/2") magnet.
TN 37 B orientable tweeter.
Max. power handling: 150W.
Nominal, power handling: 75W.
Sensitivity (2.83 V/1m): 93dB.
Frequency response:
50Hz-18kHz.
Grill included.
what would you recomend me getting for a set of speakers. need new ones to put into my '92 firebird, old one blew
Focal 690ca vs kicker05ks693 6x9
I would stay away from 6x9's, they don't sound to great. If your gonning with coaxial's, go with 6 1/2's. I'd say stick with the focal's there a good brand. I'd say upgrade your front speakers, and leave the ones in the back off.
With good speakers in the front you will have a better soundstage. If you got an amp, use that, because it will make them shine.
Robert Wollenberg
I saw once many years ago where someone put 10" subs in that spot in the b piller. I don't know how it sounded. I agree with the others, oval speakers suck. Not to mention putting too much into rear speakers. You should be able to put something good in your door or kicks. I know your dash is pretty shallow and comes with a 4x6 hole. I think it was Image Dynamics who made a replacement dash for your car with waveguides built into it. The whole dash was something like $5k. I forget these days. Getting old.
well i need something decent to put into my car. Im not putting a whole system in my car with amps and subs. What is in there now is not any good. Im limited on the install. Im not going to buy a new dash for it or kick pannels. I just want something that sounds good in the car. It is more of a performace car and handling. I just want speakers in there that sound good and better than the stock ones that have been in there since '92
