Fried amp?
jtq8713
Fried amp?
Post by jtq8713 »
i hooked up a alpine Type R 12" to a kenwood KAC-7202 in a friends car... he wanted 4 gauge wiring, it was working fine so i left.. he called me and said it stopped working... i went back and the fuse on the amp was blown. its a 40 amp fuse and the fuse in the inline is a 40amp too. we put a new fuse in and it did the same thing. i thought it was the amp so i hooked up a pioneer (i dont have the model its his amp) and it did the same thing. so i thought it couldnt be the amps so i tried a power acoustik LT980/2 and it works fine...
so are both the kenwood and pioneer fried?
You have bad wiring somewhere causing a short. Recheck all of your wiring.
yup wiring is screwy somewhere... just like justin said
jtq8713
Post by jtq8713 »
cool thanks guys....
You have a 40 amp fuse for 4g wire?
http://www.caraudiocentral.net/forums/s ... .php?t=551
check that out. You need a bigger fuse for the power wire.
High Society wrote:You have a 40 amp fuse for 4g wire?
why would he need a bigger fuse? he fused it accordingly to his amp.
how can he fit a 40amp fuse in a 4g wire inline fuse holder? Every one ive had the smallest it would go was 60, and it was the maxi kind. I didn't think they made 40's?
I guess I had that image in my head of a small 40 amp fuse just real loose in the the holder??
barrel fuses go down to 20amps i believe and maxi i think goes down to 20amps too.
if the wiring is straight and the amps are blowing fuses, your sub is bad. usually blown and causing a dead short across the coil(s) showing virtually no resistance to the output stage of the amp.
If that is the case, be glad you didn't increase the fuse sizes. All you'd do is blow out your finals that way.
