I recently purchased an eq from Justin and I'm trying to make it fit cleanly under my HU. I have it mounted fine and it works great, but now there is a big space below the eq. It is a 1/2 din eq so the space is probably about 1/2 to 3/4 of an inch. I'm just wondering what you guys usually do to make it look neat and clean? I don't have any fiberglassing skills, so that is out of the question
Help with fixing dash
kevinberry1
Okay guys, I could use a little help/advice
Any advice would be greatly appreciated. I can add pics if it is helpful too. Thanks in advance!
What type/ year of vehicle? There may be an adapter kit for it too make it look stock.
kevinberry1
It's a 99 Accord and I had a cheapo kit before with a 'pocket' that fit below the HU. It didn't look too bad but now there is just a small gap.
Justin, if that ABS plastic is easy to find I could pick it up so you wouldn't have to send it. But if you want to send it that's cool, just let me know how much it is.
- MobileAudio219
Justin from Detroit wrote:thin piece of ABS plastic. I have some if you need a sheet.
Yeah, I was going to say the same thing, abs plastic.. You might be able to buy it at a craft store?
kevinberry1
That sounds like a great idea, thanks Terry!smoker wrote:if it were me id get a big piece of abs do an iso mount on the hu and center up the eq that way you wouldnt have any gaps at all
Now any ideas about where to pick up some ABS? I may try the craft store in the next few days.
Now I just need to figure out how to get rid of the horrible engine noise that appeared after I installed the eq. I swear it sounds like a dentist's drill, lol. Of course I'll redo the ground and see if that helps.
kevinberry1
