Lights on an '03 Ford Ranger
I drive through a lot of deer-infested areas and I'm probably going to get some fog lights. But in the mean time, I was thinking that it'd be a good idea to modify my truck so that when I turn my brights on, my low beams stay on as well. However, I have no clue how to go about that. Can anyone with a clue (since I don't have one) give me an idea of how to go about this or where to look to get that info? Thanks.
- Chris from Washington
I would check out some forums that are dedicated to either Ford Trucks or Rangers.solacedagony wrote:I drive through a lot of deer-infested areas and I'm probably going to get some fog lights. But in the mean time, I was thinking that it'd be a good idea to modify my truck so that when I turn my brights on, my low beams stay on as well. However, I have no clue how to go about that. Can anyone with a clue (since I don't have one) give me an idea of how to go about this or where to look to get that info? Thanks.
When I bought my 4Runner, that was one thing that just bugged me about it. You couldn't turn on the fogs with the highs, or just have the fogs on by themselves.
checked out a 4Runner forum, and someone had already posted the mod on how to fix it. For my truck it was like a 10 minute mod too!!
Purple RS
You may want to check the legality of that mod, I know a lot of people do it. In most states, it isn't legal to use more than 2 sets of forward facing bright lights at the same time. This includes high beams, low beams, fog lights, and driving lights. That's why the factory wires up fog and driving lights to be on only with low beams and disabled with high beams.
Off road is something different and you can use as many as you want, as long as you're off road.
Check your local laws first, and after you find out if it's legal or not... although it should be on your vehicle since you have no running/ fog lamps... Here's the link for the ranger conversion: http://www.therangerstation.com/tech_library/hibeams.html
Well I've seen guys have the melting problem on full size Chevys, but that's cause they were using Hella H3 lighting in them... them things get super hot... If you use a standard Sylvania Silverstar you'll be alright... And the newer Rangers should be pretty close to this set up.
