Hero image for Running 2/0 AWG Power Cable: To Rear of Car Getting noticed
Chevrolet Camaro (1986) — Mullet
BryanEarl's avatar
I've been dreading running the giant 2/0 gauge power cable from the battery in the engine compartment all the way to the rear of the car. It's always my least favorite part of any build like this.
Optima Yellow Top Battery, Sky High Car Audio Terminals And Cable
Under the hood, I put in an Optima Yellow Top battery, Sky High Car Audio cable and battery terminals (I'll add the negative later, when I upgrade the stock electrical). I've also got a full-size ANL fuse holder right there with easy access.
To Drill Or Not To Drill
After much thought and deliberation, I decided the best option is to cut a hole on the passenger side wall (in the kick-panel area) directly next to where the antenna wire comes in through the fender. The hole has to be 1" diameter and unfortunately there was nowhere even close to that size already available within the firewall.
Removal Of Interior Trim Panels
To gain access to the passenger kick panel (and preparing for running the cable all the way back), I removed all interior trim panels on the passenger side of the vehicle. This took a lot of time, as I was being meticulous to not break anything. The 40 year old interior plastics tend to be brittle in places.
Drilling The Hole, Setting The Grommet, And Fishing The Cable
Drilling the hole went great, after identifying exactly where it was going to go. The placement on the kick panel wall made it really easy to get the drill in and out.
After drilling the hole, I cleaned up the sharp edges with a Dremel and put the rubber grommet in-place.
The more difficult process was actually fishing a wire from the engine bay, into the fender, and through the hole. Then, I was able to tape the power cable to the end of the wire and gently pull it through the fender area, and into the engine bay.
Hiding The Cable 100% From View
I've never ran a power cable of this size and it turns out that getting it hidden all the way to the rear of the vehicle was a serious task. I was barely able to get it arranged under the carpet, up through the side plastics, and out of the carpet in the very rear at the top of the well hump.
1986 Chevrolet Camaro - Running 2/0 AWG Power Cable: To Rear of Car - Image 1
Final Result: 2/0 Power Cable Comes Out Here - 1986 Chevrolet Camaro
Removed Plastics On Passenger Side - 1986 Chevrolet Camaro
Must Remove All This After Removing Plastics - 1986 Chevrolet Camaro
Everything Exposed In Kick Panel Area Now - 1986 Chevrolet Camaro
The Hole Will Be Drilled Next To The Antenna - 1986 Chevrolet Camaro
Successfully Drilled And Cleaned With Dremel - 1986 Chevrolet Camaro
Cable Through Grommet And Sealed With Silicone - 1986 Chevrolet Camaro
2/0 Power Cable Before Hiding All The Way Back - 1986 Chevrolet Camaro
