I looked at this car this spring with my Dad for him. Guy just wanted to much for it then and my Dad just didnt have the cash.
Girlfriend wants a nicer car, was talking about spending $4K on one. At which point I object as for $4K your only getting a newer car with a TON of miles.
So I went back to see if this car was there, which it was. Guys moving out so i got lucky.
$500 for the car. Need a new motor, which I found a 3800 w/36K on it for $800. Or I found a 3800 Super Charged motor for $350 in Columbus Ohio...
Wow is that thing in nice shape! Like I told ya's on the phone... If you can get the 3.8 supercharged with the computer I would definitely go that route.
And the engine wiring harness, I'm sure it's different.
The downside to the supercharged engine is it's probably been beat on, but if I'm putting a used engine into a car I'm going to tear it apart, inspect it, replace out of spec components, and go back with new gaskets...
Whats wrong with the current motor? Probably a headgasket/intake gasket which probably lead to a spun bearing????
You can have the crank cut, cyl honed, buy new bearings and rings, and have the heads resurfaced, and buy a new oil pump for less than most junk yard motors.... AND THEN YOU KNOW WHAT YOU TRUELY HAVE!!!!!
I'd spend a few hundred extra now and go thru whatever engine you put in now, rather than having to worry about "what if" later...
If the motor is locked up it might be just the air plenum, they had a problem with them and they would leak coolant down on top of the motor and lock the motor up because all the coolant on top of the piston. Easy fix if thats whats wrong and fairly cheap ~$300 if you do it yourself or less. or if it has a knock that sounds like a broken rod it might be the harmonic balancer. The rubber goes bad in them and its bang back and forth. thats an easier and cheaper fix. I would deffintly buy it even if it has a bad motor. They are very nice cars way better than a caddy.
Nah its not the gasket. He had that replaced with a brand new one then the issue happened.
It was some sort of knock? He has the current engine somewhat tore apart- was checking for bent rods. All are straight.
Justin,
My dad told me to rebuild that motor but Im against it. Its about $140 for a gasket kit then all the other parts/time. I found a motor for $800 with under 40K on it out of a 2003 impala. So Im just gonna drop it right in
Ryan from Ohio wrote:Nah its not the gasket. He had that replaced with a brand new one then the issue happened.
Justin,
That sounds like a decent deal. I'd still replace the rear main seal, its not very expensive and it'll be right there.
I'm going to try and change the lower intake gasket on mine (pretty sure thats what it is), but theres a chance that the coolant in the oil did some damage to the crank/bearings...
If thats the case, I'm probably just going to rebuild the one I have..
