subs off and on
Mitsu
subs off and on
Post by Mitsu »
i read some of the other threads on the blown speakers and stuff, but my problem is a little different i think. So i turn on my car and the subs still hit like they normally would, then all of a sudden it stops, and this happens all the time, sometimes it stays off and sometimes ill hit it and it will turn on again, i checked the connections and they seem alright, oh and i dont know if this has anything to do with it but when i change the bass or sub W level sometimes the deck goes off and on once really quickly. Anyone know the problem.
What i have:
i have a sound storm labratories Force F200.4 200W x 4-channel amplifier
and 2 C4 12" subs 700W 4 ohm in a enclosed box
plus a separate 12 aluminum eclpise sub
And a older Alpine HU
I have the subs hooked up so that channel 1 and 2 is bridged wit 8 ohm load
Strange. I know for sure it is either your amp or the head unit, which one, is a different story.
I'm leaning toward the head unit, but...
Has it always done this? Have you reconnected everything to both the head unit and amp?
spkrman
Post by spkrman »
i'm curious...
how is this setup wired???
is it cutting off @ high volume, or is it just random.
Mitsu
Post by Mitsu »
i think that i have everything connected, and it has just started doing this, it randomly goes on and off, but most of the time it is off, i dont even have to turn up my volume, sometimes it just doesnt work.
I wired it with the 8 ohm load here, (option 2)
http://www.crutchfieldadvisor.com/learn ... dance=SVC4
6three6mafia6
Post by 6three6mafia6 »
well you got 2 difirent subs, you probably screwed up the wiring somewere, are ALL the subs the same independence?
I think he meant impedance
spkrman
Post by spkrman »
KikiTheCat wrote:I think he meant impedance
since I don't have anything to really add to this topic.
I'd just like to say that we all need to celebrate impedence day on this july 4th. :cheers:
I dunno, I think you may get a lot of resistance at first... before it becomes an accepted holiday.
The post office would love it though. they love any reason to avoid work for a day.
Fishy
Post by Fishy »
Eww, thats awful Kiki.
:embarrass
-Fishy
Mitsu
Post by Mitsu »
ok so i figure that the settings on my amp were the problem i set the bass boost up quite a bit, then the subs only worked when i set the frequency almost the highest i could, what should i set these at?
