Sound Stage tuning.
another thing done on occasion, is a cross-path for the front stage, instead of aiming each speaker set right at your head, to give a wider soundstage, if you know how to work with phasing to align the two signal paths. Anyway, you want to avoid beaming, but make sure both paths are unobstructed, and be careful of reflective surfaces like large glass panes in the same path as your head. First and Second order reflections can really mess ya up.
Another note on axis alignment: Be aware that different speakers perform much differently off-axis. Some have a very wide dispersion, and others much narrower. This will greatly affect how they respond in your car.
Kick pods are widely regarded as a great location in many cars for front stage placement. They allow you to have the speakers on-axis (pointed at you as opposed to across the cabin left to right, so the speakers are in phase with your ears, reducing cancelation and reducing the need for DSP manipulation which is always a plus.) they are discrete, and they can give a good location for reducing path obstructions and reducing beaming with longer, straight signal paths that are easily adjusted or tweaked with a little time alignment work from the DSP.
there's a lot to consider when you get into a well designed system for SQ. That's been my goal for the past twenty or so years, and I still don't know it all.
cool mr grinch
Post by cool mr grinch »
i was figuring that i would point both tweeters closer to the center of the car than directly at me, once i find a good mounting point.
James-aka-Cool Mr Grinch
cool mr grinch
here is my testing setup, i still need to do the passenger side.
NorthQuad
Post by NorthQuad »
That area down near the floor looks like it gets lots of foot traffic.
I would personally try to stick it (noooo, not up my bum) just above the factory speaker grill. That empty spot in between your change dish, truck popper button, speaker grill and below the door handle there.
I'm no pro and am more of the resident douche around here I think. But I'm pretty sure it would sound better if it were placed in that spot above the grill. It would definitely be safer up in that area, I'm sure.
cool mr grinch
well, i have decided to mount the tweeters on the door panel above the midrange speaker, i like the sound and they will be safe from my work boots, i just need to come up with some pods.
NorthQuad
Post by NorthQuad »
Should be good. Can't wait for pics!
You're gunna post pics, right? :)
cool mr grinch
falkenbd wrote:They are hard sons of bitches to come by. I tried for my 8445..
i found and ordered one from http://www.pacificstereo.com/eclipse-mei-100.html.
cool mr grinch
i want to change my tweeters, the size of the tweeters i have has become annoying, i need suggestions on smaller but exceptional tweeters that will work well in my sail panels.
falkenbd
Post by falkenbd »
what tweeters do you have now?
running passive or active?
cool mr grinch
focal tn 52s, they are part of a component set.
