g-man wrote:the cars harness didnt fit on the unit so i took all its pins out and replace it with the one that came with the unit. and got this problem
So then somewhere in the pin switch you got something F'd up.
g-man wrote:well yes i know......i came here so someone could giude me what to do to find the f'd up part
I'm not trying to be a dick just trying to understand what you did. We cant really guide u until we know exactly what the problem is what you've done and what you have tried to correct it.
We don't know what you changed on the pins or where the pins were or are supposed to be. We wont really be able to tell you what to change. Your remote wire should have nothing to do with the problem your having. Sounds to me like you switched the 12+ and Switched. Go back and try to figure it out not much we can really do for ya.
Tim Strong http://upscaleaudiodesigns.webs.com/
Email: [email protected]
X-box Live Gamertag:quad drpr
