Yep, my almost two year old JL 12w6v2 is dying...the spider is detaching from its resting place on the basket. Im gonna try crazy gluing that sucker back into place. The only reason I noticed is because there was a rattling at higher volumes and certain notes. If this is gonna royally F my sub then laugh at me now.
The spider material is porous so I guess the spider doesnt create an airtight seal with whatever its covering ? In my mind securing the spider back down will stop the rattle, hence forth making my sub back to normal. Let me know if this is correct, or if im just a moron.
JL sub, spider detached
Before you do anything check this out. I don't know how well the crazy glue will work, but that link will help you find the best type of glue to use in your situations.
http://www.caraudiocentral.net/forums/s ... .php?t=508
I wouldnt use a "crazy glue"
Goto a decent home improvement store or Hobby store. Ask for CA Glue
Dragon_fire
Dragon_fire
As long as the voice coils didn't become misalligned enough to scrape the motor you're probably ok. I took apart a 5 1/4" mb Q to resolder a broken voice coil lead and glued the thing back together with contact cement. It lasted about a month before the former began separating from the spider. I glued it back with some 3M 5200 and its been going strong for 6 months now. In fact I can't really tell the dfference between it and the "good" driver.
-Fishy
-Fishy
