dual 4 ohm
daykareboards
dual 4 ohm
k, i am have a mind blank... i'm gettin a dual 2ohm sub and a dual 4 ohm sub... how can i wire each so they present a 4ohm load to the amp?
You cant...daykareboards wrote:k, i am have a mind blank... i'm gettin a dual 2ohm sub and a dual 4 ohm sub... how can i wire each so they present a 4ohm load to the amp?
To do Ohms like that THEY HAVE TO BE THE SAME EXACT SUBS.
So no you cant combine these like you think you can. Yes it will work, no your power output wont figure out to what you thinbk it will.
daykareboards
daykareboards
the dual 2 ohm one just run a jumper from one vc + to the other vc - and use the remaining + and - back to the amp the dual 4 ohm one if you do that will give you 8 ohms, but if you connect all + together and all - together and back to the amp will give you 2 ohms. there is no way to get 4 ohms with that one.
daykareboards
