Need amp rated ~100wattsx4 @2Ohm
Robert Wollenberg
Post by Robert Wollenberg »
2 Ohm with an RMS power handling of 55W? What sense does that make? Do they make an amp that only pushes 55WRMS at 2 Ohm stereo?
Robert Wollenberg
Infinity's lowest 2 Ohm power output comes from their multi-channel amp and is 107 WRMS at 2 Ohm. Just be carefull with the volume nob I guess.
That's really dumb. If you haven't bought the speakers yet, get the 4 ohm version instead.
Otherwise, the ARC Audio 4050-XXK does 4x90 at 2 ohm.
grizbiz
Post by grizbiz »
This is getting a little out of hand. OK first of all, the speakers that I am getting are: 6.5 componets, 6x9's . As you can see, they are 90 and 110 watt respectively. Also they are 2Ohm. With these two facts, what would you recommend for an amp? I am sorry for any confusion and hope that this clears things up. Thank you for taking the time in the first place for the help.
You would probably save a little bit of money if you bought 2 separate, 2 channel amps. Maybe, if you did a little bit of research, you could find something for cheaper (ebay). But one of these 2 amps should so just fine:
http://69.93.14.227/index.cfm?fuseactio ... uct_ID=271
http://69.93.14.227/index.cfm?fuseactio ... uct_ID=270
And if you havent bought them already, you may want to look into something a little different, something that has regular 4 ohm v.c.'s.
but hope this helps slightly.
tedd
iondb
Post by iondb »
How about Audison's srx4. Puts out about 85w @2ohms. Or RF's punch 4004 amp.......just a thought.....
two4fifteen
Post by two4fifteen »
you could try kicker's kx350.4 its 90w x 4
grizbiz
Post by grizbiz »
I was looking at that from the start and like the sounds of it. I wish JBL would come out with a power series amp that would have similiar specs to the kx350.4. I think the px300.4 would be too much if it is even 2Ohm stable. Thanks for the reply two4fifteen.
two4fifteen
im running the kx350.4 myself and i love it. i have the kx600.1 for my sub too and they look great together
grizbiz
Post by grizbiz »
That's why I want the px300.4 cuz I have the bpx1100.1 for my sub. I'd like to have the same brand but I guess I would rather have it sound good.
