Car engine stalling...
Hey I've had this problem a few times in the last few days now. I will be driving and out of nowhere my car will stall (when im accelerating usually into 2nd or 3rd)...I think it is the battery becuase it will not start back up w/o my battery jumper or a jump, the engine will just turn over. So I know I need a new battery, but since it is stalling during normal use wouldn't thatalso mean my alternator is not powerful enough?
- Chris from Washington
Could be your alternator too?
If it isn't charging the system, your car is running off the battery only. So once your battery gets weak, your car could die.
Happened to me once, My alt died and I was trying to get home so I could just replace it myself. Well the car used up the last of the battery power, and the car just died. That day sucked...
Yeah I have a Kenwood 600 watt going to 2 12" W3's and a Kenwood 280 going to my Kappa's.
Chris are you saying my alternator could be totally dead and i am running solely off of the battery?
BTW I went to autozone where they checked the charge on my battery and they said I needed a new battery becuase it wasn't holding a charge for as long as it should. (I am getting a new battery tomorrow afternoon)
Well the problem has taken a weird turn. I ended up getting a new battery (needed one anyways) which didn't really solve the problem...here is what has happend the last few times.
I was driving on expressway going about 70 and all of the sudden my tach dove from about 2800 to about 1400 and I felt a huge drag. After about a second it went back to normal.
And also today i was engaged in drive but stopped at the taco bell drive thru and i stalled, but was able to start right back up.
The only things I can think of that it could be is a fuel problem (fuel injector? filter?) or an electrical problem. If it was the alternator, how could I check to make sure?
