the input level is at 4v, the LPF is at 32hz or a Little above, and the bass boost is barely past 0.. and all the "bass" settings on the HU are -0 or below.. anyway this has nothing to do with the problem.. so anyway onto The Problem... i was uptown and a piece of speaker wire came off somehow and well i didnt know what it was at the time til i took it off, but anyway i was tryin to put the sub back in and i was hookin up and the bass started to play again when i hooked it back up and i heard a noise comin from the cone.. so i move the speaker wire around where it connects to the sub and it stops.. i let go and it starts.. i hold it in a certain position and it stops..so and so forth.. so i get annoyed and put it in the position so it wont make the noise and look on the other side to make sure its ok and i get ready to put it in and i see a spark coming from the other side of the sub.. ok i freak out and check it out and well that black thing where the tinsel leads connect, one side is almost broke somehow, i guess it happend when i tried to put the sub back in, anywya can i just glue it back together? i have left over gorilla glue i used to seal the box up, will that work? could i make some sort of brace? like using a toothpick or something? im sure a picture of the Actual sub and crap would work better but i forgot too and dont feel like taking it back out at the moment. but here is a quick pic of the sub, but not when its broke.. but that black piece where the tinsel leads are connected as i said, one of em has almost broke off..
its right where the tinsel leads connect.. its almost broke off if i remember.. i was too upset to really check it out.. but what can i do? and what do you think the noise is? :help:
