Getting to the heads?
then get the block bored, new pistons and rings, new crank if that rusted.. still sounds like a recon engine is a better bet if that thing is ate up in the bottom end
Ryan from Ohio wrote:Transmission is good, as I just replaced it.
Motor is pretty much rebuilt except rings and bearings...
May as well keep going IMO, already got enough money into it. $200 more of parts and it will be good for a long time...
Time to start pricing bearings and rings, oh joy!
I said the same thing about that POS Camry I had. There is a point where you have to forget about the money you've lost and give it a boot in the ass.
Well bearings are $55 for the mains and like $35 for the rods...
I can polish the shaft out myself where Im working now.
I was hoping I wouldnt hear about boring the block out... I may pull the pistons and run a hone up them... Hopefully I can do that with the heads on...hehe... Just clean the block out with white inspection rags ;)
I dunno man, this car is pissing me off. Ive got a fair amount of cash wraped up in it at this point. If I re-ring it, and put new bearings in it then I would say its had a motor rebuild... Then it would probably last well over 100K miles more...
