Heres some of the amps ive been lookin at to power 2 jl w1's 12's (there svc 4ohm) and 150 rms each. btw if u have any suggestions of other amps just name them, i dont wana spend more then 200$, ill prob get the amp of ebay.
1. '06 KICKER ZX300.1 300 W. MONO
300 watts x 1 @ 2 ohms rms Rated (Birth sheet included with actual tested power)
2. Orion 300d Class-D Monoblock
300W RMS x 1 @ 1 Ohm
600W Peak x 1 @ 1 Ohm
(im not sure of the 1ohm since the subs r svc 4ohm, dont i have to wire them to a 2ohm amp?)
3. Kicker zx 350.2 110 watts RMS x 2 at 4 ohms (175 watts RMS x 2 at 2 ohms)
350 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode)
4. Phoenix gold xenon 400.1 400W x 1 (4-1 ohm) Power
Also i plan on gettin front components soon and i have an oldschool blue 150.2 orion cobalt amp i was goin to use for them but i was just wondering if this amp would work for both the subs and the components
DIAMOND AUDIO D3 400.4 4 CHANNEL 400 WATT AMPLIFIER
RMS Power (4 ohms) 57 watts x 4 chan.
RMS Power (2 ohms) 88 watts x 4 chan.
RMS Power (1 ohm) Not Stable
Bridged RMS Power 182 watts x 2 chan.
Peak Power Output 700 watts approx.
- Im wondering if i can power the subs by bridging them 182x2, then the components at 88x2 ?
Which amp for 2 jlw1 12's
I would go with either of the first 2 amps listed.
As for using that diamond, i dont think it will work the way you think its goin to. By bridging it, you are occupying all 4 channels. You COULD look into a 3 channel that can run your comps as well as run a sub on the 3rd channel...but since you already have another amp, i'd just buy a separate sub amp and use the one you have as your component amp.
Hope this helps.
Hope this helps.
