System upgrade...
Bwcad1 wrote:the 06 l7s are the only ones i would every buy the solo x's i would buy but none others. my favrite speaker size is 15 maybe its because i used a 15 to break 150 for the first time. or just because i like the size vs usability of them.
Punctuation is your friend. :)
And remember: there's no replacement for displacement.
i dont like puncuation it makes me angry lol!
Bwcad1 wrote:i dont like puncuation it makes me angry lol!
ERRRRRRRRRRR nor do i periods usually mean trouble :happy055:
I've heard a single 15l7 off a 500-600 watt amp in a show room and it was still freakin loud.
Post by CaptainPioneer »
I dont like going into show rooms to hear subs... They always sound different in a car app
Robert Wollenberg
Post by Robert Wollenberg »
I've got two first generation L7 solobarics in a 5.25 or so ported box. They sound pretty damn good. Only running them with 300 watts though. I'm about to go sealed with them this weekend to conserve space. :(
Robert R. Wollenberg
Audio Alchemy, Owner
Phone: (325) 480-2790
E-mail: [email protected]
Web: www.audiochemy.com
www.abilenecaraudio.com
www.abilenecaralarms.com
Ampresearch
Post by Ampresearch »
Airforceyooper wrote:I've got two first generation L7 solobarics in a 5.25 or so ported box. They sound pretty damn good. Only running them with 300 watts though. I'm about to go sealed with them this weekend to conserve space. :(
i understand the space issue but those subs REALLY want a ported box. if you do go through with going sealed you are going to want to up your power by quite a bit. I dont feel that you will get enough output to make you happy with a sealed box and your current amp.
GL to ya
martin0804
Post by martin0804 »
Does anyone know of any tutorials on installing a second battery?
Actually running a second battery is really easy.
1st: You will need a battery isolator (these can be bought all over the web and many times at local truck & rv stores) and you can normally get a kit with all the wiring so your not messing with all that too.
2nd: I recommend you start with 2 new batteries (both a like) this way your secondary doesn't try to pull all the power from the alt from the isolator (remember the isolator is meant to charge the second battery second).
Pretty much cut and dry from that point. You just need to decide where you want your second battery before going shopping. Trunk mount requires more wiring and under hood mount normally means moving (or doing without) the washer fluid tank.
Ampreasearch.... You talked about how Smoker's Avatar was disgusting, but you know that Yours isnt really a step up from his old one... LOL
Ampresearch
CaptainPioneer wrote:Ampreasearch.... You talked about how Smoker's Avatar was disgusting, but you know that Yours isnt really a step up from his old one... LOL
hahaha i was waiting for that. clearly done on purpose. not to worry i'll change it.
