which wiring?
herndog
which wiring?
Post by herndog »
I have two re12s (dual 4 ohm) and a kicker kx350.2...should i wire the subs series/parallel or parallel/parallel?
swimmerdude
Post by swimmerdude »
you want to do series/parallel to get a final 4ohm load so you can bridge that amp. Like wiring option 2 in this link... http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp=Dual+Voice+Coil+-+4+ohms+x+2
