Rebuild or replace?
Listening to it with a wrench it doesnt sound like its in the top end...
I would like to think it was (in a way) but its just not. Whatever it is its coming from the lower part of the motor...
It has to be bearings... hasta!
[email protected]
Post by [email protected] »
Try parting it out first and see how that go's
Because the junkyard is always there for the last straw
Well I paid $45 to have the car scanned.
I was told the knock sensor is showing for #6 cylinder. #6 is the cylinder that had the largest amount of rust in it.
I have bought a replacement piston.
Tonight I pulled the motor from the car. Its the only way to do this.
Ive got enough money in the car I dont mind throwing another $250ish into it.
I gotta buy a ring set ($68), head bolts($28), head gaskets($30), and a crank shaft w/bearings($137).
WIsh me luck ;)
joeyc
Post by joeyc »
good luck and godspeed!! :D
JC's Customs
Hey, by the time you're done, it'll be good as new! For a few miles at least... :)
JoshKeller
Post by JoshKeller »
i can testify for the tranny fluid working. Fixed my old sunfire's tapping. thing has 210,000 and my sister still drives it to school everyday.
Way past a small tick or knock, its a cracked piston.
Im going to take the pistons/crank out tonight. WIll post pictures of my findings soon.
Ryan from Ohio wrote:Way past a small tick or knock, its a cracked piston.
I'm going to guess a spun bearing...
Well I got #6 out. No crack that I can see in the piston.
THe pin didnt appear to be cracked either. I pressed it out on the hydraulic press @ work. Messed up the old piston :(
Pressed on the new one and it doesnt float well?
I guess it was supposed to be heated first???
arghhhh
