4-bolt mains for lower-end stability at high power outputs
High-tin 41,000 PSI tensile strength iron alloy for ultimate strength
Nodular iron main caps for additional strength
Screw-in freeze plugs for additional more strength and stability
Front cross-over lifter oiling for high RPM valvetrain capability
Siamese bores with specifically engineered drillings between cylinders for maximum wall stability and gasket sealing with street capable cooling performance
This will be the great equalizer
