Time for more LEDs!!!
- Chris from Washington
You'll need to know the specs of your LEDs, but once you have that here is a nice tool to help you.
http://led.linear1.org/led.wiz
A good place to go to learn about LED retros is HIDPlanet. They really go all out with their conversions.
You have to use a resistor, see the led calculator I posted. It will help you determine the resistor needed, depending on the # of LEDs.veggie-man wrote:my friend and i just took a LED and blew it up because we put 3 times the recommend voltage to it... how do you control the flow of power to the lights, they seem very sensitive especially having THAT many lights.
Looks REAL good man!
If you are going to use them as a tail/brake light, you'll also need to have a couple diodes to stop current from backfeeding.
I wish I would have taken some pics of the back.
I just soldered in little 'jumpers' using small pieces of stripped phone/networking wire. Just cut them really small and held them in place with tweezers then soldered it to one leg of one LED, then soldered it to the leg of the next LED.
It actually turned out pretty nice looking.
I cut the board to shape just using a pair of scissors.
Oh if you really want to get fancy, you can etch your boards with traces. but that takes alot of planning and time.Darthness wrote:dont you have to mix some chemicals or something to make the board?
But for this project I just used the preholed boards w/solder pads from radioshack.
If I were to start selling these, then I etching the boards might be a good idea, but just for me. The preholed, and wire jumpers were good enough.
I know someone from another forum that made all kinds of things with the etch boards.. he did several nice LED mods to his cars. i may have to try your way though, ie, i might want to do a green dome and trunk light or something. what kind of $$ do you pay to DIY a mod like that.Chris from Washington wrote:Oh if you really want to get fancy, you can etch your boards with traces. but that takes alot of planning and time.
- Keith
